What is this part?
   / What is this part?
Do you mean the nut on the outside of the differential or is there a nut inside also? The nut on the outside still has the cotter pin in it and appears to still be tight.
   / What is this part? #12
He is talking about the nut on the inside of the housing. Nut on the outside is just there to hold 3pt arm.
I was afraid that was the case. Looks like I need to spend a day working on it, don’t want it to wear and cause any serious issues.
   / What is this part? #14
Since I said 'go in thru the pto hole'.. you can assume that means 'inside'.
I was really hoping I read that wrong. Need to get out the manual and read up on pulling the pto shaft.
   / What is this part? #16
drain oil and 4 bolts.. not much too it.
I degreased and pressure washed it today so when I have a day I’m going to get it knocked out.
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
