What is this part called? It is off a Ford 1220.
   / What is this part called? It is off a Ford 1220. #1
JasperFrank
Elite Member
Ford 1220
Its the lower mounting pin for the three point.
Thank You Arto. Got 'er ordered! :)
For good measure, i found out that the rear bolt to the pin broke off. Oh, that's going to be fun to remove. :)
   / What is this part called? It is off a Ford 1220. #7
At least its the bolt that broke, on mine the casting where the bolt screws in was broke from the previous owner.
They repaired it and its been fine for the 23 years I have owned it.
   / What is this part called? It is off a Ford 1220. #9
Not bad if you have a welder. Even better when it's in cast iron. Just weld a nut to it and unscrew the remainder of the bolt.(y)
Extracting the broken bolt was far easier than I ever imagined. I bought a left hand 3/8th drill bit. $11 dollars and a screw extractor $8. Used a punch to set the bit, and got 1/4 inch in to the broken bolt. Then it just backed out using a flat head screw driver. I never even had to use the extractor. And even though I was working at an angle the drill bit never touched the internal threading. I really thought this was going to be a nightmare, and it turned out to be nothing at all.
I will say that one should be careful if they are use to only useing a FEL with an three point attachment as a counter weight. In my case the three point pin broke so I tried to use the FEL with out the counter weight. This was extremely dangerous and stupid, and I need to buy a new set of pants. :)
  • Good Post
Reactions: JJT
14ft. Deer Gate (A53424)
14ft. Deer Gate...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
