What is this on power poles?
   / What is this on power poles? #11
Didn't realize there was such a problem with critters climbing utility poles. I wonder how it would work to keep squirrels out of bird feeders.
I have bird feeders on 10 foot high 4 inch PVC drain pipe poles. Squirrels and raccoons can't get a grip and it is too large to "hug" and climb.
Bruce
   / What is this on power poles? #12
I have wrapped miles of wood hi-line poles from below the bottom phase all the way to the bud due to wood peckers, also as a side note when you change out a pole with a big woodpecker hole that has been hollowed out into a nest, if you will cut that section of pole out and either bolt or band it to the new pole they will usually not mess with the new pole but will stay in the old pole piece that was their home to start with.
   / What is this on power poles? #13
Keep critters from climbing up and contacting the conductors.
Oh that's what they WANT you to think! I'm not fooled, no sir! You see that black color? That is used as a signal to the black helicopters as to where to go and who to shoot first when the globalists take over and come for our precious bodily fluids!
   / What is this on power poles? #14
Around my area they put that stuff on some power poles to prevent damage from bears , they say because of tiny vibration bears think there are bugs in the poles and chew on them even though there are no bugs. Most poles have nothing extra applied .
   / What is this on power poles? #15
Hmmm - I've not seen anything like that around here. Maybe all the climbing critters around here are just to lazy.
   / What is this on power poles? #16
They use themhere too, possums put on quite a light show when they step between insulators, the only problem is they jump from branches onto the wire and run along it to the pole, amazing how an animal that size can balance and run on a wire.
   / What is this on power poles? #17
Oh my YES ! I know several linemen here. They have corrected outages from squirrels / racoons, even a snake climbing up and shorting out / chewing wires.
   / What is this on power poles? #18
At one time sightseeing nearby, we happened to walk by a power pole just as two seagulls were squawking at each other as they sat on the wires. "Mine, mine, mine!" One thing lead to another and one of them flapped its wings at the other. BANG! Feathers drifting everywhere and two loud thunks as the seagulls hit the pavement next to us. It was electrifying...
Most poles have those guards in the city around here, but not so much in the country, leading me to think the main target is rats.
All the best,
Peter
   / What is this on power poles? #19
They are usually installed only at transformer locations.Not all power companies use them.
   / What is this on power poles? #20
I'm with @bunyip . I usually see critters climb trees and then move across power lines like a catwalk. Rarely see them climb the power poles...unless they are in a treeless prairie.
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2007 KENWORTH T800 HEATER TRUCK (A53843)
2007 KENWORTH T800...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
2012 C.GALLEGOS 130BBL (A53843)
2012 C.GALLEGOS...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
