What is this lever for ? FarmPro 2420
   / What is this lever for ? FarmPro 2420 #1
flimmy
Mt. Pleasant , Pa
farmpro 2420
What is this red lever for ? I have a FarmPro 2420
   / What is this lever for ? FarmPro 2420 #2
Looks like the compression release for cold weather starting
   / What is this lever for ? FarmPro 2420 #3
Yup, compression release. But you have to follow the linkage to the rear of the valve cover to make sure it's actually hooked up and available for use.
//greg//
   / What is this lever for ? FarmPro 2420 #4
Yep, that is the compression release. It connects to the rear of the valve cover via pushrod, and when rotated so the lever is up, opens the exhaust valves so the engine won't build compression.
I use mine for every start as it saves wear on the engine. It allows oil pressure to build in the crank and rod bearings before you apply compression loads. It also allows the starter motor to quickly spin the crank up to full RPM with low load and less startup electric current. If you have had the misfortune of a headgasket leak which put coolant in a cylinder, it will prevent the piston from hydraulically locking and possibly bending a rod or the crankshaft...
I set the throttle, start the preheat and lift the decompression lever. Then I crank the starter and when it is up to speed, drop the decompression lever and the engine starts...
   / What is this lever for ? FarmPro 2420 #5
I watched the oil pressure gauge while the starter cranked. Soon as I saw a rise on the needle, I let go of the compression release.
//greg//
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2008 Ford F-250 (A52748)
2008 Ford F-250...
CFG Industrial MX15RX (A50121)
CFG Industrial...
