What is this lever for ? FarmPro 2420
   / What is this lever for ? FarmPro 2420 #1
flimmy
Mt. Pleasant , Pa
farmpro 2420
What is this red lever for ? I have a FarmPro 2420
   / What is this lever for ? FarmPro 2420 #2
Looks like the compression release for cold weather starting
   / What is this lever for ? FarmPro 2420 #3
Yup, compression release. But you have to follow the linkage to the rear of the valve cover to make sure it's actually hooked up and available for use.
//greg//
   / What is this lever for ? FarmPro 2420 #4
Yep, that is the compression release. It connects to the rear of the valve cover via pushrod, and when rotated so the lever is up, opens the exhaust valves so the engine won't build compression.
I use mine for every start as it saves wear on the engine. It allows oil pressure to build in the crank and rod bearings before you apply compression loads. It also allows the starter motor to quickly spin the crank up to full RPM with low load and less startup electric current. If you have had the misfortune of a headgasket leak which put coolant in a cylinder, it will prevent the piston from hydraulically locking and possibly bending a rod or the crankshaft...
I set the throttle, start the preheat and lift the decompression lever. Then I crank the starter and when it is up to speed, drop the decompression lever and the engine starts...
   / What is this lever for ? FarmPro 2420 #5
I watched the oil pressure gauge while the starter cranked. Soon as I saw a rise on the needle, I let go of the compression release.
//greg//
2002 Scag STT61A-27KA Turf Tiger 61in Zero Turn Mower (A50322)
2002 Scag...
2014 Ford F-550 XL (A50120)
2014 Ford F-550 XL...
2024 AGT LRT23 Mini Track Loader Skid Steer (A50322)
2024 AGT LRT23...
2013 Ford F-650 Truck (A51692)
2013 Ford F-650...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
PT 6'x16' Single Axle Farm Wagon (A50121)
PT 6'x16' Single...
