What is this hole on the transmission for? (JD 5085E)
   / What is this hole on the transmission for? (JD 5085E) #21
I'm about to put down a deposit on Tuesday for a 5085e. Would you recommend it?
   / What is this hole on the transmission for? (JD 5085E) #23
if it was a vent you would think it would have some kind of a filter/ check valve to keep dirt and debris out.
   / What is this hole on the transmission for? (JD 5085E) #25
what puzzles me most is that it is a threaded hole..
   / What is this hole on the transmission for? (JD 5085E) #26
Many times there is a cotter key in the hole. It is put in loose enough to jiggle around. This keeps the hole free of debris.
   / What is this hole on the transmission for? (JD 5085E) #27
It's a bad seal or the gasket on front of trans, if it has one. Better get it fixed before you have to buy a new clutch.
   / What is this hole on the transmission for? (JD 5085E) #28
I've ran the tractor 3 times since I posted the OP, since my dealer won't be open until tomorrow.
The first time, I ran it about 30 minutes. No leaking.
The second time was about 1 hour, there was some dripping afterwards.
Ran today for about 2 hours, no dripping.
I think we should hold tight and not speculate, as the last Magicman reported on Sept 1, no leak.
And the serviceman was going to check it out maybe next week.
   / What is this hole on the transmission for? (JD 5085E) #29
No problem with it. Buy the tractor, use it and have fun.
   / What is this hole on the transmission for? (JD 5085E) #30
so dirt wont hurt baby tractors
9ft Flatbed (A57453)
2022 Deere 325G (A57148)
2022 Deere 325G...
Service Truck (A59230)
Unused Quick Attach Plate (A55272)
Unused Quick...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
