What is this hole on the transmission for? (JD 5085E)
   / What is this hole on the transmission for? (JD 5085E) #1
Magicman710
South GA
JD 5220, JD 5055E, JD 5085E, JD 5100E
I noticed a small puddle of hydraulic fluid on the concrete below my new (5 hours) 5085E this morning. I found where it was coming from, this hole on the bottom of the transmission case. I initially thought it was leaking at the seal, but after I wiped the area I saw it puddling around this hole.
It's very similar to other holes around the bottom of the tractor, but all those holes have a end. It's threaded like the others but looking up into there is no end, its just black. I'm able to stick a nail through the hole and it comes out with hydraulic fluid on it.
   / What is this hole on the transmission for? (JD 5085E) #2
Maybe a drain hole to allow oil to exit, but leaves the question why is there oil there to drain. I'd stuff a shop towel into the hole (so it doesn't drip on the floor) and watch it over a period of time (as well as notify the dealer in case later it is a warranty issue).
I must say, that area is sure clean and spotless, save for the oil drips.
   / What is this hole on the transmission for? (JD 5085E) #3
LOL, welcome to owning an E! To answer your question no, it should not leak there or anywhere else. But it does and it will. Call the dealer and they will hopefully fix it up for you.
I realize it shouldn't leak, I'm just wondering why in the world is there an open hole there in the first place.
   / What is this hole on the transmission for? (JD 5085E) #5
To let out any oil that is leaking ?? Likely don't want it pooling up where it is not needed. Check with your dealer..
You can go to jdparts.com and see just what is inside this part of the tranny. May help you to know.
   / What is this hole on the transmission for? (JD 5085E) #6
fords and many other have a bellhousing weep hole to keep rear main leaks and tranny input shaft leaks drained.
   / What is this hole on the transmission for? (JD 5085E) #7
I checked mine and it has the same hole, doesn't leak. If you have a leak out of that hole I suspect either a crack, porus casting, or the hole is drilled just a touch too deep. Proper fix is a new trans case, but some dealers will want to do a quick and easy fix.
   / What is this hole on the transmission for? (JD 5085E) #8
Not sure how you came to those conclusions that a proper fix is a new transmission case. Doesn't seem to add up to an oil leak. Maybe a seal or gasket or nut not tight.
   / What is this hole on the transmission for? (JD 5085E) #9
If the leak is coming from a threaded hole which is only drilled part way through the casting where is the fluid coming from?
I would however make sure that the oil isn't coming from somewhere else and pooling around that hole. I had several oil, coolant, and hydraulic leaks on mine at 20 hours, mostly due to fittings/clamps not tight, and poor quality clamps.
   / What is this hole on the transmission for? (JD 5085E) #10
In the first post he states it is not a blind hole. Is it a blind hole on your tractor?
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
Kubota F3990 (A50322)
Case IH 1020 Platform (A50514)
Case IH 1020...
Hay Forks (A50515)
Hay Forks (A50515)
