What is this electrical connector please? See pic
/ What is this electrical connector please? See pic #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
It's on a Kubota M4700 for the headlights, probably a common auto type thing but I did not want to cut it off to take it to match.
Thanks for any help.
/ What is this electrical connector please? See pic #2
Yep, looks like a common 3 wire connector. So common that you could probably study it and maybe even plug some male spades into it to verify size and then go to an automotive supply store. Take a pic with you with a tape measure in the pic showing size. Get a better pic than this one.
/ What is this electrical connector please? See pic #3
Very common on motorcycles too.
Look Here about halfway down the page.
/ What is this electrical connector please? See pic #4
If you can't find a match, I'd bet that standard male blade terminals will slide into each female opening on that connector. I do that a lot when connecting up to custom plugs. They may have odd shapes and arrangements, but they often use standard blade terminals.
/ What is this electrical connector please? See pic #5
Does it plug into the rear of a sealed beam headlight on your tractor? If so it is pretty standard
/ What is this electrical connector please? See pic #6
It is an accommodation for the addition of some future electrical accessory.
There seems to be about a dozen "standard" 3 pin connectors in a T configuration for headlights.
Messicks sells the part for $27. I was just hoping that someone could rattle of the part name here and I could find it for a few bucks, instead of shoving spades into it and taping everything up, which I did.
/ What is this electrical connector please? See pic #8
G'day most auto parts stores have that style of connector on the shelf and they are usually sold as a pair ( i.e male and female ) along with new terminals to fit to the wires.
Jon
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2021 YANMAR VIO25-6A EXCAVATOR (A63276)
2021 YANMAR...
