What is this called and where can I find some?
   / What is this called and where can I find some? #1
TBone
Platinum Member
LA (Lower Alabama)
Kubota L-2501 HST
I'm posting this for my brother in law. He recently bought an old Super A and had planned on using it in his garden. He got a bunch of loose parts and plows with it but wasn't familiar enough with the tractor to know what he needed. After getting some help to set it up, he found out he only has one of these "feet" where the plows attach to. Not sure if that's the right name for the part. Picture is attached hopefully. The top of the part is a large round shaft. It has a spring loaded mechanism that trips if you hit something solid and the plows attach to the bottom. Any of you folks out there know the proper name for this thing and where he might get 3 of them? THANKS
BIL just called and said he found some. He can get to plowing now.
   / What is this called and where can I find some? #3
Thats a cultivator shank in the picture ----sweeps bolt on the bottom.
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A50397)
Morooka MST 660VD...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 Kioti RX6620 Tractor with Loader (A50490)
2015 Kioti RX6620...
2015 Chrysler 200 Limited Sedan (A48082)
2015 Chrysler 200...
