kaferhaus
Bronze Member
Recently bought this little tractor (MF 1010 4WD std trans). I'm really enjoying the little tractor and it constantly surprises me how much work it's capable of considering it's puny.
My uses for it are landscaping and gardening. Mostly landscaping...which it's the perfect size for as it will get into tight places.
I have the following implements I use with it. Box blade, grader blade, rear scoop, tiller, boom pole, bush hog and carry all. I will be buying a middle buster/sub soiler in the near future. Does not have a loader.....sigh.
At the left rear of the tractor under the fender I found the following little gem. Previous owner only used the tractor for bush hogging his deer plot and had no idea what this was for. (He was more tractor stupid than I am).
The hose just loops around and is connected back. I assume one end is pressure and the other return, but which is which and what can I do with this setup? there are no valves or controls anywhere else on the tractor. The hyd pump is engine driven and supplies 3.5 GPM..
