What is this "58" 841 worth?
   / What is this "58" 841 worth? #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
I looked at an 841 today and I need advice on what it is worth. The 3 point lift works fine, even cold. PTO works fine, it is very greasy and dirty but nothing that cannot be cleaned up. It is priced at $2700 with a Ford loader. The loader has a dedicated pump, hyd controls, and hyd reservoir. It is a 4 speed with a shuttle shift. There is some issue with the transmission shift that the owner says is is a $135 fix. It appears that the shift handle is all worn out and it is hard to find the correct gear. I would prefer to buy it without the loader but not sure I can. The loader is off but the owner says he will be putting it back on.
Any and all thoughts............
Bob W _MG_8061_resize.JPG_MG_8062_resize.JPG_MG_8063_resize.JPG_MG_8064_resize.JPG_MG_8065_resize.JPG_MG_8066_resize.JPG_MG_8067_resize.JPG
Here is a really bad pic of the loader.
   / What is this "58" 841 worth? #3
id say the tractor is pretty well priced right.but since you say it needs a known repair.id prolly offer $2400 and you do the repair.or $2700 with him doing the repair.
   / What is this "58" 841 worth? #4
Decent tires, power steering, at least 1 maybe 2 new rims, tin is good.
Probably has a Sherman reversing transmission judging by the linkage.
It would sell fairly quickly here at that price.
   / What is this "58" 841 worth? #5
loader = resale value, even if you don't need it or put it on, when you go to sell having the loader will get a lot more looks that without.
   / What is this "58" 841 worth? #6
Off topic here, sorry, but what is the gizmo just behind the coil and dipstick?
Jim
   / What is this "58" 841 worth? #7
Jim
um.. behind the coil and dipstick. uh.. the engine block?
or if you mean aft of it.. . um.. the hyd pump ?
   / What is this "58" 841 worth? #8
what part is hard to shift, the sherman or the 4spd?
is the 4spd shifter wobbly and loose and that's why it's hard to shift.. but if you put it in t he right place it does shift fine? if so, easiest fix is to find a surplus tranny cover and shifter. I have seen them from 65-100$ on ebay, though don't currently know of one. if he knows of one, get the info.
If everything works. ps, etc. and you can get the part or make it work.. then it's likely priced right. you always offer less and see where it goes.
the pto seal, if it leaks.. can be fixed for under 20$ for the seal and gasket. the loader looks good.
Bob WView attachment 394601View attachment 394602View attachment 394603View attachment 394604View attachment 394605View attachment 394606View attachment 394607
   / What is this "58" 841 worth? #9
Aft, yes. So it's the hyd pump. Thanks
Jim
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
