Buying Advice What is the smallest machine with a front category-1 3-point hitch and PTO
   / What is the smallest machine with a front category-1 3-point hitch and PTO #1
60047
Still searching
I have a Kubota L4330. It is an outstanding machine, but I am getting tired of constantly twisting my back and neck for hours at a time. Is there a machine (not necessarily a tractor) that accepts *standard* 3-pt attachments in the front? If not, how big of job is it to put a 3-pt and PTO in a tractor?
A PowerTrak is close to what I think I want, but I do not want to modify all of my attachments to be used by a PT. Why do they not make their machine cat-1 compatible?
   / What is the smallest machine with a front category-1 3-point hitch and PTO #2
In Europe, that would be an easy find. Front 3 pt + PTO is very common from smaller tractors (usually 30HP) to the bigger ones.
In the US, not so much but there may be other solutions, like the Ventrac tractors and stuff like that.
Do the Ventrac and Steiner require proprietary attachments?
   / What is the smallest machine with a front category-1 3-point hitch and PTO #4
Yes they do.
I would suggest an Antonio Carraro with reversible platform, but that can also be hard to find over there and the smallest one with that option is 70HP I believe.
   / What is the smallest machine with a front category-1 3-point hitch and PTO #5
Try Googling “Front Link” to see if they make one for your model. Looks like they may have one for the
late model L series.
   / What is the smallest machine with a front category-1 3-point hitch and PTO #6
2 cameras on ROP and 9 inch display.
   / What is the smallest machine with a front category-1 3-point hitch and PTO #7
The Kubota system is pretty sweet, but appears to be only for the 60-series. I have a 40-series. Also it is not for standard cat-1 implements.
   / What is the smallest machine with a front category-1 3-point hitch and PTO #9
Only thing I've ever found for front 3pt mounts with PTO are the aftermarket kits by Zuidberg and Larforge.. and alternatively some 3pt adapters for SSQA mounts that use hydraulic motors for a PTO drive - for example:
Skid Steer Quick Attach to 3-Point Adapter | Skid Steer Solutions
Though the adapters generally require higher hydraulic flows than many subcompact/compact tractors provide (lowest flow requirement I've seen such adapters is 10GPM). ...which may be doable with a 3pt mounted hydraulic power pack, but that's further added expense and hose routing....
Doesn't seem to be many straight forward options in the US for front mounted 3pt and PTO on tractors ....at least from what I've seen. :confused3:
   / What is the smallest machine with a front category-1 3-point hitch and PTO #10
What are you trying to do with a front PTO? That makes a difference. Tractors are made to pull for heavy ground-engaging work. For light work like mowing and snow blowing it makes sense to work off the front, and there are attachments to do that right now.
rScotty
2014 8ft. S/A Utility Trailer (A55853)
2014 8ft. S/A...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
Forward 10,000lb Two-Post Electric Auto Lift (A55852)
Forward 10,000lb...
Bobcat T590 (A53317)
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
