What is the recommended RPM
   / What is the recommended RPM #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
We bought our New Holland TC40D HST 4WD used and I was wondering what the recommended, if any, RPM reading should be to have the tractor work most effectively.
   / What is the recommended RPM #2
Is that a Romulan bird of prey in your avatar? nice! I give you my personal 2 cents. It depends on the application and type of transmission you have. If I'm using a rotary cutter and want to run it as specified pto/cutter rpm of 540 then I have to run the engine at a rpm to achieve that. with my tractor it is around 2500. on some other rig between 2500-2800 rpm ..give or take some. A lot of time my task does not require 540 rpm and I run my rig for the RPM required for the task when engine is not logging and comfortably do the work. HST is a bit different as you need to maintain rated rpm to get the rated flow of the hst pump/motor combination.
For HST most efficient rpm is the rated rpm (2500-2800)
JC,
   / What is the recommended RPM #3
I have a NH TC30. I do it by sound but 1200/1300 is a good idle speed, 1500 is a good moving speed, 1800 is a good working speed, 2000 good for heavy work (FEL gravel). I bush hog at 2000 (really could do it at 1500 if I want to- though tractor emblem says 2400). Mine is a 9x3 manual, so it may be different than an HST. Your owners manual might have some suggestions. It also changes by 2 or 4 wheel drive and terrain. If it hesitates or feels weak- give it more gas(diesel). These are pretty tough tractors.
   / What is the recommended RPM #4
I have a TC40D.
- If you are running the PTO(I have rotary mower, PTO Chipper) and the implement needs 540 pto rpm, then you will be around 2500-2600 rpm. The pto light, and the "540rpm" light should go on.
- The rest, as another poster mentioned, I do by ear and feel. If it is lugging, then I give it some rpm. Most everything I do(besides pto use) is 1500-2200 rpm.
Have you used a HST before? Remember, it is not like a gas pedal; if you start to lug, let up on the HST a little, and maybe give it a little more throttle too. Pushing harder on an HST is kind of like shifting to a higher gear on a standard tranny...
I would say, get a manual, cause it has all the useful info on the tractor. I just looked in my manual; it does not give much useful info on the HST and rpm...
Quick Attach Pallet Forks (A47384)
Quick Attach...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
