What is the most standard width on the compact tractors?
   / What is the most standard width on the compact tractors? #1
bdog
Elite Member
Texas
John Deere 6130M
Been a while since I owned one and I know it varies but in general. I have some big old chisel plows / field cultivators I am going to cut down and put new hitches on for small tractors and sell. I was thinking of making them 5' wide but wanted to make sure that would cover the tires on an average small tractor. I am think tractors in the 30 hp range.
   / What is the most standard width on the compact tractors? #2
My 1710 Ford is right at 60" wide
   / What is the most standard width on the compact tractors? #3
62" here, but tire tracks are slightly narrower.
   / What is the most standard width on the compact tractors? #4
66" is a good width for the 30 HP and under CUT's, if you want to make sure to completely cover the tire tracks.
   / What is the most standard width on the compact tractors? #5
Mine is about 73".
Thanks for the info. I measured the tool bars and they are 10' . If I cut them in half and put 12" sweeps on them all the way to outside edges it should cover a little over 5'.
   / What is the most standard width on the compact tractors? #7
Mine is a little under 72". What about cutting them to order? I would want something in the 7' range for my tractor but someone with a sub compact might want a 3-4'. Just a thought.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
J-BAR 4' ROATRY MOWER (A52708)
J-BAR 4' ROATRY...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
Kubota M5-111 (A53317)
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
