What is the highest watt led light bar my L3240 can run?
   / What is the highest watt led light bar my L3240 can run? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I'm looking to mount a led light bar on my L3240. I plan on getting the widest one that will fit in the bottom side of the ROPS and obviously mounting it on the bottom side of the ROPS with a swivel mount that will allow it to point forward or backwards. I'm probably looking at a 120-200 watt bar and just making sure it won't overload the electrical system. It will probably be used with the factory headlights on.
   / What is the highest watt led light bar my L3240 can run? #2
You could run up to 250 watts (20 amps x 12.5 Volts = 250W). It would be a continuous load, so the wiring needs to be at least 12ga. and on a dedicated, fused circuit off the battery.
   / What is the highest watt led light bar my L3240 can run? #3
Not the same tractor, but probably similar alternator output. I run a 108W tied right into the high beam switch, because the high beams are pretty much useless. No extra switch to deal with. No problems so far. Pics are low beam - high beam. I think the 108w is plenty.
   / What is the highest watt led light bar my L3240 can run? #4
   / What is the highest watt led light bar my L3240 can run? #5
Do you guys think I could get by with two 150 watt bars or should I back down to a 100 watt? One would be up front in the place of the factory head lights and the other on the ROPS.
   / What is the highest watt led light bar my L3240 can run? #7
Rigid original version D2 35 watts per pair silly bright. Best warranty and reviews I've found, very happy image-2320179489.jpg
Forward/rearward
   / What is the highest watt led light bar my L3240 can run? #8
100w LED will be more than enough light for tractor use, you probably don't even need that much.. Something like this should suffice..
https://www.superbrightleds.com/mor...vy-duty-off-road-led-light-bar-72w/1218/2859/
.. I run 150W off road on my jeep and that's plenty in the middle of a blackend trail in the trees...
FYI, save some $$$ and buy from Amazon... Amazon.com: 20 led light bar: Automotive
I've run plenty of these on my jeeps on the trails and fullsize and they are worth the money savings... Even if you had to replace in a few years still cheaper than buying the expensive ones.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
2011 PETERBILT 367 T/A DAY CAB ROAD TRACTOR (A51243)
2011 PETERBILT 367...
2017 CATERPILLAR 336FL EXCAVATOR (A51242)
2017 CATERPILLAR...
