What is the front/rear gear ratio on an m7040?
   / What is the front/rear gear ratio on an m7040? #21
Sounds like they put the wrong tire on?
   / What is the front/rear gear ratio on an m7040? #22
Better too long than too short. I've bought several pairs of chains over the years. They have always been too long. Very easy to shorten. Very hard to lengthen.
   / What is the front/rear gear ratio on an m7040? #23
Certainly I too have had tire chains that I could fit either by welding in links or removing links. TSC sells special tools to add and remove links.
With these studded Trygg chains, the studded portion consists of a series of diamond shaped sections that need to just meet as they come around the tire. Too long and there is no where to connect the links which connect the diamond pattern. All links are welded so using the TSC tool is not possible to alter the chains.
If you look closely at this photo, you can see the smaller diamond shape at the rear mid height of the tire. With this uneven diamond pattern on the tire, the chains were very rough on the road as the pattern of the chains riding on the pavement changed once per revolution.
At the distributor, they adjusted the size of each diamond and removed one full diamond to get a proper fit. These chains, including the side chains are so hard a 3 foot pair of new bolt cutters cannot break them. I had resorted to using an angle grinder with a cut off wheel but it was very soon apparent that this was beyond the normally expected "fitting," of many less expensive ladder style chains.
To sixdogs, the issue arose became the tires Kubota provided did not meet internationally accept standards as to size. The inner diameter fit the wheels. The front rear/ratio seems ok as the drive line is not winding up. If I check the diameter of the front tires they too must be deviating from the Tire and Rim Association standards.
The tire size only became an issue when I bought chains which were designed to not require fitting.
Dave M7040
   / What is the front/rear gear ratio on an m7040? #24
I'm curious about tire options and determining just how much overrun I have. I've tried to get the number from my dealer with no luck. Thanks.
OK....getting back to the OP's question, there is a pretty easy way to determine just how much overrun that a tractor has in various loading and traction conditions. And it is handy info to have. Luckily it is simple to do and requires nothing much more than a notebook, a measuring tape, and some way to mark the tires. I've posted details in the GENERAL FORUM section under OWNING/OPERATING.
Good luck with it. I'd post a link, but don't know how. Maybe someone can help with that.
Enjoy,
rScotty
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
2000 ADDCO DH1000 Message Board (A49461)
2000 ADDCO DH1000...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
