What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval?
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #1
mikepsl
LX 178 & STX 38
Good morning,
I canエt find the factory recommended oil change intervall in the handbook. Does anyone know the recommondation from Kawasaki?
Thanks
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #2
Oil is cheap, Kawaski engines not so. Once a year or at 50 hours.. whichever comes first.
The factory has no real good idea what conditions you run your engine, so go on your own. Have fun..
IMO
:welcome: to TBN
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #3
I have an X300 and change my oil and a quality oil filter at the end of the mowing season, about 50-60 hours of mowing time. Also, I change the oil when the engine is hot. As soon as I kill the engine, I drain the oil. It drains faster and cleaner, contaminants are still in solution and don't have time to settle in the crankcase.
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #4
I downloaded the service manual for the FD440V and it shows every 100 hrs, which is the same as just about every other Kawasaki engine.
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #5
I think changing the oil at 100 hours is fine, but remember if your mower sits all winter long then what ever contaminants are in the oil are going to settle in the crankcase. As the years go by that turns to sludge. I like knowing that there is clean oil in my mower as it sits all winter.
   / What is the factory recommended LX 178 Kawasaki FD440V Oil Change interval? #6
The OP was asking for the "factory recommended" oil change interval. On my X500 with a Kawasaki FS730V I use dino oil and change the oil and filter every 25 hours. I typically put 50 hrs per season on the engine, mostly mowing, and I figure two oil changes a year is not excessive for a 2-cylinder air cooled engine.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
