Flail Mower What is the difference
   / What is the difference
   / What is the difference #12
You can loosen all the nuts a turn or so and then mow a bit. If the clutch slips you can tighten each nut an equal amount and mow again. What you wanting to do is make sure the disc are not seized with rust, dirt or other material. They need to be free to "slip". Then you want the disc to be pinched by the bolts enough to allow your tractor to mow tall grass without slipping. Just keep adjusting until you reach that point.
The concept of a particular torque setting may work fine, I just prefer being sure things can work as they were designed and do slip when a extra heavy load is applied. A little practice and you'll get the idea.
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
2020 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
