What is the difference between this and a std pole barn?
   / What is the difference between this and a std pole barn? #1
bfisherman11
IL and WI
LS G3033H
I was looking at metal buildings. I found this and the price with delivery and install sure sounds inviting. Also they say 29 ga steel which is what I think a good pole barn is.
I know a pole barn has a wood frame but isn't this as good?
https://www.metalcarportdepotllc.com/22-Feet-Wide-Metal-Buildings-s/2215.htm
The 22 by 36 is the size I am considering. Right now my tractor is in a 10x16 wood shed.... This would be a good upgrade. I would store my tractor, an 18' car carrier trailer and hope to have room for a work bench.
Thanks,
Bill
   / What is the difference between this and a std pole barn? #2
Well, the price is good, but I'd want 27 gauge metal. Smaller number is thicker metal, like wire. I reckon ye have ye land all leveled out for them? They probably require that. Keep us posted.
Just looking right now. Have a spot picked out, but the LS will need to do some work to clear some brush and flatten the spot out. Around here, I would expect a pole barn this size to be 8-10K.... Have not priced one in a while though.
Bill
   / What is the difference between this and a std pole barn? #4
I thought 29 ga (0.0135 inch) was rather thin. I've been looking at similar buildings.
/edit
For instance Home Depot sells a "Temloc" brand which is 18 ga (0.0478 inch) which includes 2 windows and a floor frame, for about twice the price in what I'm looking for - a 12x20.
   / What is the difference between this and a std pole barn? #5
I'm in same situation. My place is sloping though, plus about 30 pines I have to cut to get it ready. I think I'll check with that company too, since even if I build a pole barn, I want to put siding on.
Yeah, I wouldn't want 29 gauge.
Looks like they offer a heavier gage roof supports (12 or 14). Maybe they have heavier roof side metal too. I agree, 27 would be better.
   / What is the difference between this and a std pole barn? #7
Great prices, but I'd be concerned about building height, not to mention the small doors. I wouldn't be able to fit my truck through a 9x7 door, let alone my cab tractor.
   / What is the difference between this and a std pole barn? #8
Nothing wrong with 29 gauge. Most people use it for walls here. If you worry a lot about hail dents, 26 for the roof is the usual option, but a lot of roofs are done with 29.
   / What is the difference between this and a std pole barn? #9
You know Kenny, you're right, 29 gauge would be fine. Actually, that's what my metal roof is, nary a problem in many years. I just have this old fashioned idea of way over building, but if you really don't need to, no use to do it. I need to rethink my storage barn too.
   / What is the difference between this and a std pole barn? #10
Built a 24x30x10 pole barn last summer for just under $8K. Gravel floor.
425729d1432156522-what-difference-between-std-pole-image-2233210408-jpg
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2001 MACK CX SLEEPER (A54313)
2001 MACK CX...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
