What is the difference between this and a std pole barn?
   / What is the difference between this and a std pole barn? #1
bfisherman11
IL and WI
LS G3033H
I was looking at metal buildings. I found this and the price with delivery and install sure sounds inviting. Also they say 29 ga steel which is what I think a good pole barn is.
I know a pole barn has a wood frame but isn't this as good?
https://www.metalcarportdepotllc.com/22-Feet-Wide-Metal-Buildings-s/2215.htm
The 22 by 36 is the size I am considering. Right now my tractor is in a 10x16 wood shed.... This would be a good upgrade. I would store my tractor, an 18' car carrier trailer and hope to have room for a work bench.
Thanks,
Bill
   / What is the difference between this and a std pole barn? #2
Well, the price is good, but I'd want 27 gauge metal. Smaller number is thicker metal, like wire. I reckon ye have ye land all leveled out for them? They probably require that. Keep us posted.
Just looking right now. Have a spot picked out, but the LS will need to do some work to clear some brush and flatten the spot out. Around here, I would expect a pole barn this size to be 8-10K.... Have not priced one in a while though.
Bill
   / What is the difference between this and a std pole barn? #4
I thought 29 ga (0.0135 inch) was rather thin. I've been looking at similar buildings.
/edit
For instance Home Depot sells a "Temloc" brand which is 18 ga (0.0478 inch) which includes 2 windows and a floor frame, for about twice the price in what I'm looking for - a 12x20.
   / What is the difference between this and a std pole barn? #5
I'm in same situation. My place is sloping though, plus about 30 pines I have to cut to get it ready. I think I'll check with that company too, since even if I build a pole barn, I want to put siding on.
Yeah, I wouldn't want 29 gauge.
Looks like they offer a heavier gage roof supports (12 or 14). Maybe they have heavier roof side metal too. I agree, 27 would be better.
   / What is the difference between this and a std pole barn? #7
Great prices, but I'd be concerned about building height, not to mention the small doors. I wouldn't be able to fit my truck through a 9x7 door, let alone my cab tractor.
   / What is the difference between this and a std pole barn? #8
Nothing wrong with 29 gauge. Most people use it for walls here. If you worry a lot about hail dents, 26 for the roof is the usual option, but a lot of roofs are done with 29.
   / What is the difference between this and a std pole barn? #9
You know Kenny, you're right, 29 gauge would be fine. Actually, that's what my metal roof is, nary a problem in many years. I just have this old fashioned idea of way over building, but if you really don't need to, no use to do it. I need to rethink my storage barn too.
   / What is the difference between this and a std pole barn? #10
Built a 24x30x10 pole barn last summer for just under $8K. Gravel floor.
425729d1432156522-what-difference-between-std-pole-image-2233210408-jpg
2015 CASE 580N (A47477)
2015 CASE 580N...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
