What is the dif. between the 1735M and the 1835M?
   / What is the dif. between the 1735M and the 1835M? #1
bebop86
NJ
Guys- I am looking to pick up a preowned tractor to replace my Dads- 40 yr old Kubota L235- Have settled on the Massy but notice that they went to the 1835 over the 1735- What is the dif?? Also we will be using the tractor to mow about 20 acres of grass that is somewhat on a slope- Would you guys rec. going shuttle or Hydro-I may not have a choice buying used- Any advise would be appreciated- thks
   / What is the dif. between the 1735M and the 1835M? #2
They went back to an Iseki engine in the 1835M; the 1735M had a Shibaura.
I would imagine both are great, but personally I would take the Iseki machine.
   / What is the dif. between the 1735M and the 1835M? #3
The HST makes it much easier to change speeds while mowing. For example a lower gear when heading up or down hill or a higher gear when on smooth ground. With a shuttle that doesn't have synchronized shifting you have to stop to change gears.
If you need to back up to get under trees very often the HST is much better.
   / What is the dif. between the 1735M and the 1835M? #4
Recommend staying with the Iseki engine for simplicity.
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
