What is the compression suppose to be in a KM385 Jinma 284
   / What is the compression suppose to be in a KM385 Jinma 284
This is the one that was over my head:
//greg//
I hear ya on that, there is a little more to add and take away to get the true rating
anyhow motor is shot gone done, its out of the tractor now, so its time to rebuild or replace this thing,
the cam gear bolt backed out which sheared off the key, somewhere in the pan is the other half of it, valves smacked the pistons not bad but enough to make me think to replace them, bent 2 valves #1 intake #2 exhaust, kinda weird but that is how it goes, all the push rods are bent, and no telling how the crack looks or rods at this point, did split the tractor and removed the front section,
so for now I really do not think worrying about the compression is that important anymore LOL!
   / What is the compression suppose to be in a KM385 Jinma 284 #12
Sorry for the luck, hope you can get the beast back together and running soon...
   / What is the compression suppose to be in a KM385 Jinma 284 #13
Tommy thanks, I called earlier today and got a quote on one, I'll have this motor completely apart tomorrow then I'll figure out which route I want to go, I know if I rebuild it I might go a little over board
So one question I did not ask Thomas is what kind of warranty does this motor have on it, the new (create) motor?
I found almost every part I'm going to need to rebuild this motor, I'll post some pix soon
So here are a couple of photo's
this is the cam shaft, the key way is completely mushroomed out, I have only half of the key, this is behind the front cover which has never been removed
with the front cover still on but the inspection over removed you can see the large bolt just sitting in the hole, completely backed out of the cam shaft gear
the front of the motor with the front cover removed, the cam gear is hollowed out
   / What is the compression suppose to be in a KM385 Jinma 284 #17
Most of the time the parts cost to rebuild the engine is around $ 1,200.00--1,400.00 for the parts,you also have to remember that does not include any labor, head work,injector pump, alt, water pump ect.A injector pump is $ 450.00, alt, $150.00, water pump $ 170.00, starter $ 190.00, it does not take long to add up The complete crated engine has all of that, it's ready to bolt in, even comes with a new flywheel.
I would take a good look at the complete engine route, your time, labor, equipment, tools has to have some value ?
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
UNUSED FUTURE QUICK ATTACH PALLET FORKS (A54757)
UNUSED FUTURE...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54756)
(4) GOODYEAR...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2024 Kubota KX080-4 Midi Excavator (RIDE AND DRIVE) (A50775)
2024 Kubota...
UNUSED 200 AMP 13' JUMPER CABLES (A54756)
UNUSED 200 AMP 13'...
