Woodstock Walt
I've had quite a bit of success using an 8' landscape (York) rake to do exactly what you're describing. No gauge wheels. I adjust both the angle and pitch of the rake to pull material back into the road and just slowly drag the shoulder. The rake typically gathers the finer material while leaving the larger rocks on the shoulder. Adjust your depth accordingly, you don't want to pull up any topsoil. Do this until the material is pulled in to the width you want the road to be. Usually two or three passes adjusting the pitch each time to round the shoulder and pull material back into the center of the road.
The idea is to build up row of material in the center of the road. Then make a couple passes down the road with the angle straight and the pitch just slightly towards the center of the road. This should theoretically leave you with a nice crowned road.
I drag mine with the 3 pt. hitch and manually get off and adjust the rake each pass (I'm gathering parts to install hydraulic top and side links to simplify this step in the future).
A forward facing rake on a skid steer with hydraulic pitch adjustment at the least seems like it would be a great tool to do what you want.
