Mowing what is the best speed
   / what is the best speed #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I just acquired a ford 1310 to mow a couple of acres. I have a 4' finish mower. I am mowing on about a 30 degree grade. What is the proper speed/range to mow with this set up?
Thanks
   / what is the best speed #2
The proper speed is the speed at which you feel comfortable you are not compromising stability.
I am not worried about stability. I am more concerned with proper grass cut without overworking finish mower.
Thanks.
   / what is the best speed #4
That is the speed when it quits cutting cleanly. More likely to compromise stability then cut too fast. I can use up to 8th out of 12 gears without cutting to fast for my RFM.
2 piece Bale Ring Feeder (A50515)
2 piece Bale Ring...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
UNUSED FUTURE MINI EXCAVATOR HYD 18" AUGER (A51244)
UNUSED FUTURE MINI...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
