Mowing what is the best speed
   / what is the best speed #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I just acquired a ford 1310 to mow a couple of acres. I have a 4' finish mower. I am mowing on about a 30 degree grade. What is the proper speed/range to mow with this set up?
   / what is the best speed #2
The proper speed is the speed at which you feel comfortable you are not compromising stability.
I am not worried about stability. I am more concerned with proper grass cut without overworking finish mower.
Thanks.
   / what is the best speed #4
That is the speed when it quits cutting cleanly. More likely to compromise stability then cut too fast. I can use up to 8th out of 12 gears without cutting to fast for my RFM.
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
TEST BID LOT (A50775)
