What is the best battery operated chain saw
   / What is the best battery operated chain saw #71
Trying to decide... What model and battery do you have? Do you use two batteries?
58 volt. only purchased one battery. I got it for my wife on our 1km driveway...she can never get the gas chainsaws going . I have used it to cut a bunch of trees...big ones. It cuts awesome...I was truly impressed. I cut allot of wood as we heat with wood.....-36C with the windchill today in Parry Sound.
   / What is the best battery operated chain saw #72
Not sure which one you have... a little confused. You say 58volt but my understanding is there are three battery classes AI, AK, and AP and two sizes in each. But all are 36volt.
   / What is the best battery operated chain saw #74
I have been looking at the cordless chainsaws 35 volts or more and I will probably go with the Ryobi because I already have the 40 volt string trimmer and battery. I like the Echo, Ego and Husqvarna also but I have no other battery tools for any of them. All seem to have fairly good reviews. I will probably get rid of several of my gas chainsaws and just keep a larger one for firewood.
   / What is the best battery operated chain saw #75
Another vote for the Kobalt (or the Greenworks) 80V.
I tried it and I think the Stihl battery-powered is a better chainsaw. But I bought the Kobalt so I could get the 18" trimmer, and therefore also brushcutter and pole saw attachments, for the same battery ecosystem. Unfortunately that couldn't be done for the Stihl, Echo, or Oregon (I can't remember about the eGo).
I like the fact I can put the Kobalt in the back and forget about it, and when I need to clear something over the road or path it's there, ready to go at the push of a button. For my use case, that's more important than whether it's the best, highest-use-cycle, or longest-lifespan chainsaw out there. Probably if it were the other way around, I would have picked something else, but so far I'm happy.
[First post on TBN]
   / What is the best battery operated chain saw #76
   / What is the best battery operated chain saw #77
[First post on TBN]
That was my thoughts on the 40v HF line.
Last summer I did see the Kobalt line trimmer and lawnmower in the back of a PU at McDonald's. I am sure the mower would be the right size for small areas without the headache of gas mowers.
   / What is the best battery operated chain saw #78
How much difference does the battery voltage make? I've got a 20 volt DeWalt system and several large capacity batteries, so I'm considering their 20 volt 12" chainsaw.
   / What is the best battery operated chain saw #79
In general, higher voltage means more torque in a motor, and therefore more oomph to do stuff.
So my 14" Ryobi 18V cordless chainsaw will trim a branch or two, but a 80V saw will handle it a lot quicker, and will also power through a log up to what's reasonable for its 18" bar, where my 18V Ryobi would get hopelessly bogged down, or take for ever in comparison.
Oversimplifying, I think your battery Wh (=Ah x voltage) will determine the total amount of cutting (aggregate area in sq in) you can get done on a single charge, while the voltage will determine the ambitiousness of what you can tackle, and how long it will take you to cut it.
Of course, it depends on more than just voltage, and I'm sure a modern DeWalt 20V will beat my crappy old Ryobi 18V by quite a bit. However, it's only been with 40V and higher voltages that people who use gas chainsaws regularly have started saying, "hey, this behaves like a real chainsaw, not a toy". And the 56-80V offerings generally get better reviews than the 36-40V ones.
From what I've understood (reading) and been told (by pros and would-be pros), for full coverage you now do best to invest in 2 ecosystems. 18-20V for hand power tools, and ~60V+ for outdoor power equipment (chainsaws, mowers, etc.) I'm not too familiar with DeWalt (around here it's pretty price premium in general, and very much so, if available at all, for outdoor power equipment like chainsaws and trimmers), but if you're with them I would explore if you can go for their new 60V/20V Flexvolt line. You'd probably get a lot more saw with their 60V brushless, and -- hopefully, please check! -- the batteries would be backwards compatible with your 20V system though I doubt your old batteries would work in the saw. But if a 12" bar to trim the occasional branch or cut off a 4x4 post is all you need, then yes it will be overkill.
   / What is the best battery operated chain saw #80
Another vote for the Kobalt (or the Greenworks) 80V.[First post on TBN]
Have the Kobalt battery powered units improved? About 3 years ago I bought a Kobalt battery powered leaf blower (an anniversary present for my wife...just kidding) and it did not work well at all. The battery pooped out and would not power the unit - I was very unhappy with it. I decided that was the last Kobalt battery powered tool I would ever buy. But if things have changed I am willing to take another look at Kobalt.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2020 DRAGON ESP...
BLANTON 12' DRAG HARROW (A52708)
BLANTON 12' DRAG...
HUSQVARNA CHAINSAW & BLOWER (A58374)
HUSQVARNA CHAINSAW...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
