What is the actual difference?
   / What is the actual difference? #1
LD48750
Veteran Member
SE, MI
Ford 1510 Mahindra 1526
What is the difference between the 7 tooth star drive sprocket for a 3/8ths chain and one for a 3/8th LP and a .325 Chain?
Length of the teeth?
   / What is the actual difference? #2
If you measure the diameter of each of them, you will find that they all differ from each other a bit. This is so that the ends of the points on the star drive come out at the right distance apart to match the drive link spacing. (I don't use 3/8" LP chain, but I believe there is a slight difference between the 3/8" and the 3/8" low profile. This because the length of the pitch is measured at the rivets. Because the links on 3/8" LP is not quite as tall as on the regular 3/8", it sits differently on the drive sprocket.)
2019 Ford F-350 Crew Cab Auto Crane EHC-4 4,000lb Crane Service Truck (A50323)
2019 Ford F-350...
White 6065 Tractor (RIDE AND DRIVE) (A50774)
White 6065 Tractor...
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
