What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #2,781
I'll probably regret saying this but I've been known to pull light trailers in daylight with no taillights, if my truck lights are easkly visible.
   / What is some of your Pet Peeve's #2,782
I have Absolutely used plenty of trailers without lights during the daytime. Truck tail lights are still visible, and regardless, you are still suppost to maintain follow distance. Its not like anyone uses turn signals anyways, so they are a non factor :)
With that, id rather people not use turn signals at all, rather than turn them on half a mile before a turn...
And yes, I generally Do use my turn signals, but I've never even heard of anyone being ticketed over them, although I'm sure technically they are required. (They are, I checked).
   / What is some of your Pet Peeve's #2,783
Fortunately I've never had problems with a 7 blade round wiring coupler.
I've burned up 7-pin connectors, but oddly enough, never a 4-pin flat! But that's due more to application than connector reliability alone.
I'm usually towing a trailer with rechargable batteries when using the 7-pin, and those chargers pull something near 20A continuous, so any dirty or loose contact will heat up and melt the housing around it.
The 4-pin flats are never handling more than a few brake lights and marker lights. The markers pull relaitvely little current, and the brake and blinkers are intermittent duty only.
   / What is some of your Pet Peeve's #2,784
I blew a fuse on my RV once using a seven blade with the Bluetooth curt echo brake controller only time Ive had a problem with 7 blades. My RV doesn't have a integrated brake controller and the micro toyhauler had electric brakes I was pulling also had a house battery charging thru the 7 blade plus it was powering up the echo I guess. I opened up a 4 flat once to see why it failed even though the outer casing looked good the wire on the inside was corroded severely where it made contact with the prongs.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2007 International 4200 S/A Chipper Truck (A56858)
2007 International...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
