What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #911
Mine is the way that grocery stores constantly move things around. Kraft Cheese-Wiz has moved at least four times at the closest Smith's. First it's with the chips, then it was with the condiments, later they moved it onto the aisle with the noodles and now it's in the dairy section. That's just one example. Going to a big store is like a death march. I plan to organize a bunch of old farts like myself and pull a flash mob of shoppers buying one item with a full size cart, blocking aisles and driving the employees insane with questions about where something is now. Let's start a movement!
   / What is some of your Pet Peeve's #912
Comoooter traffic
   / What is some of your Pet Peeve's #913
People have argued whether the safety standards are actually the reasoning behind the demise of that old Chrysler push button system, or just coincidence that it disappeared at the same time the standards were released.
Or maybe just that that pushbutton system didn't work very well. ISTR them jamming up a lot, requiring much disassembly to fix. If I'm not mistaken those pushbutton automatic Mopars didn't have a "Park" position, just neutral & set e-brake.
Chrysler did a number of odd things, anyone remember LH thread lugs on the driver's side? They stuck with that into the early 70s.
Quirky controls didn't end in the 60s...Saabs & Suburus tended to have things in odd places well into the 80s. Remember late 70s Fords where the horn was on the signal lever.
The reasoning for this is it promotes impulse buying.
Speaking of Cheeze Wiz, the store I shopped at where I lived in the 90s had a portable display for it. As you noted, they'd move it around, generally near products you might want to use it on/with. One time I saw it in the pharmacy next to the condoms! :eek: Whipped cream, maybe but Cheeze Wiz??!? Must be one wild night! :ROFLMAO:
   / What is some of your Pet Peeve's #914
:ROFLMAO:
My dad had a 1958 Chrysler Imperial with the push button shifter. He ended up junking the car after the trans went on it and I bet he still has that shifter mech in the barn. It was heavy and complicated.....good riddance.
   / What is some of your Pet Peeve's #915
I had a 56' Plymouth with the push button shift. Never had a problem. Later I had a 63 Valiant and it had a lever in the dash as I recall. The problem I had those was, that the slant 6 ran so quiet, my brother was always trying to start the car while it was running. That led to changing the ring gear and those cast iron Power-Flites were heavy.
   / What is some of your Pet Peeve's #916
Very Zen.
   / What is some of your Pet Peeve's #917
Willys Jeeps had the reverse threaded lugs on one side too. I never can remember which side though. 🤔 I learned to keep an eye on tire jockeys as they would whomp down on them not knowing.
Kind of a self tightening feature must've been the thought. Much like the knock-off center nuts on wire wheeled cars.
   / What is some of your Pet Peeve's #918
Great idea, I'm in!!!!
   / What is some of your Pet Peeve's #919
Makes sense with center knockoffs or bicycle pedals. But there's no relation between wheel rotation direction and lug nuts in a pattern. The rotation only affects a fastener located on the axis of rotation.
I'm not sure why they would have bothered with left-hand threads on one side of a car, but I can recall countless cases of overzealous managers who didn't understand basic engineering, making similarly stupid decisions based on a half-understanding of basic physics.
   / What is some of your Pet Peeve's #920
I used to really like Cheese Whiz, particularly to make a gooey cheese dog, but they changed it years ago. Removed the trans fats? Just wasn‘t the same.
2007 KAWASAKI MULE 3010 UTV (A58375)
2007 KAWASAKI MULE...
Survey Kit (A57149)
Survey Kit (A57149)
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
WATER TRAILER (A58214)
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
1712 (A58375)
1712 (A58375)
