What is kubota factory grease?
   / What is kubota factory grease? #1
TruckinFool
Colorado
Ford 860, M7040
Need to grease my FEL for the first time and it seems everyone likes the moly stuff. I picked up some of the valvoline moly EP thats grey in color. What does kubota use from the factory? Can I just add or do I need to replace? Kubota website has two grease listed one blue polyurea and one black, moly-lithium. Are either compatible with the valvoline moly? Or should I just go get the kubota stuff?
   / What is kubota factory grease? #2
Kubota doesn't use any grease for the loader at the factory. They are assembled and greased by your dealer. He uses what ever grease he likes. When my new Kubota L3400 was delivered several of the grease zerks still had paint over them and no grease in the joints. Just a wad on top of the zerk where the dealers mechanic put a grease gun to it, but did not notice the zerk took NO grease. I scraped the paint off of the zerks at about 3 hours when I noticed "sqeaking sounds" coming from the loader. And, personal opinion here, but in a low speed application like a loader, I don't think it matters what grease you use as much as the fact you grease at least every 10 hours of use to keep the dirt/water out of the joints. I doubt you can figure out what grease was used upon initial lubrication, unless you ask your dealer. I would just grease it well now, with the grease of your choice, and use it a bit, and grease again to help force out the original grease, and then you will know what kind of grease is in it.
James K0UA
   / What is kubota factory grease? #3
From my understanding the synthetics like RoyalPurple are best at holding moisture out. I just find the price is a RoyalPain :D
   / What is kubota factory grease? #4
Be careful of the polyurea grease. Most PU are incompatible with other grease systems.
see here >> The Skinny on Grease Compatibility
   / What is kubota factory grease? #5
James K0UA
I agree.
Aside from some compatibility and spec issues, frequent greasing with a quality grease is more important than some high buck, special, super "moly" grease. Mine came with Kubota moly grease in the pins, however I use LubexEP Irving Quality Lubricants & Specialty Fluids :: Grease Its pretty much THE standard grease around here, from excavators to tractors.
Dealer said "Its just um grease".... I pulled a pin and it looks like the color of motor oil. Brownish. Not sure if that tells you anything but is the valvoline moly EP compatible with general all purpose grease? Or should I just make the mess and purge it all because I dont know whats in there?
   / What is kubota factory grease? #8
Grease it often and don't worry about it. TSC has Red grease on sale for 2 bucks a tube. That's a dollar off per tube.
   / What is kubota factory grease? #9
I use the red stuff. I don't worry about what brand. I figure if my wife, who is an excellent cook can cook by color, I can grease by color.
"Needs more red." :D
Joe
   / What is kubota factory grease? #10
I use the red stuff too.. the Brown, might be New Holland Ambra. My dealer gave me 2 tubes of that with the tractor as they are also a New Holland dealer
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
