What Is It??????
/ What Is It?????? #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Lost my neighbor to Cancer two years ago. Was helping his widow clean out his Machine Shed and found this. Thought it a very interesting item. First one I've ever saw. Thought it might be interesting and entertaining to discuss it and confirm what it is.
I'll start by offering these pics. :)
/ What Is It?????? #4
It measurers rpm. Press the rubber tip against the center of a spinning shaft so it can show how fast the shaft is spinning. Im on my phone so I can稚 see it very good but thats what it looks like to me.
/ What Is It?????? #5
I believe it came with some attachments. Did you find anything else with it? It will work like that for one application.
/ What Is It?????? #6
It’s a AC Delco rpm test gauge for auto mechanics
/ What Is It?????? #7
Used to use a similar device to tach fan speeds. The end of the fan shafts had a small centered indention that the rubber point of the tachometer rested in. Now they use digital tachometers with lasers. There's even a phone app for tach work. My, how things change!
/ What Is It??????
All very good responses. Perks interest doesn't it.
For some reason I have it in my head the AC is representing Allis Chalmers? Maybe used on old AC tractors prior to tachometers to set governor speed???
It's spring loaded and centers back to zero. If I twist it quickly I can make the indicator bounce back and forth. Appears to be maxxed out at 4,000 rpm. I'll try it on a drill and check that.
/ What Is It??????
Here's a couple pics to give you size relevance.
/ What Is It?????? #10
WE used it in the "old days" to check pto rpm and then mark the throttle setting with paint or pencil to know where the proper setting should be. Back be fore tachometers were on a tractor.
I don't think it had anything to do with Allis Chalmers.
/ What Is It?????? #15
The AC lettering on top is definitely from AC/Delco, the electronics division of GM, not Allis Chalmers.
/ What Is It?????? #16
AC = Albert Champion
Albert Champion (cyclist) - Wikipedia
...In 1905 he incorporated the Albert Champion Company in Boston to make porcelain spark plugs with his name on them. Three years later founded the Champion Ignition Company in Flint, Michigan. In 1922 he changed the name to AC Spark Plug Company...
Bruce
/ What Is It?????? #17
It would be handy to have for PTO speed reference.
/ What Is It?????? #18
I know Allis Chalmers combines used a Tachometer to time the belts on the shakers depending on what you were harvesting. Clover seed, wheat, oats, etc..
/ What Is It?????? #19
Here is mine made by Starrett Co.
Anyone else have one?
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
John Deere 5000-Series Loader Frames (A63116)
John Deere...
