What is it with Harley riders?
   / What is it with Harley riders? #231
I have more than one motorcycle, but I ride my Harley the most.
I bump the throttle when down shifting, but I still have the stock exhaust my bike, and I have no intension of removing it.
SR
I blip the throttle on manual transmissions when down shifting to match the engine’s RPMs to the transmissions RPMs so you don’t lurch your vehicle forward when the clutch is engaged.
Makes for a smoother slowing down process.
   / What is it with Harley riders? #232
I haven't owned a standard for decades other than my current bike, an '09 Kawi Voyager but that's something I've always done. I've always thought it was a necessity if you wanted a smooth downshift.
   / What is it with Harley riders? #233
I rode a Harley - FXDL -for more than 25 years. I never had to bump the throttle when coming to a stop. Now I wonder what I was missing. It had a turnout exhaust system. It could be VERY loud if I wanted it. Seldom found it to be necessary.
you don't have too... it depends on if you use the brakes or if you mostly use the engine as brake or how fast you down shift while breaking... if you use your break and wait until the rpm and speed is very low to down shift then you don't have to rev match (bum the throttle)... lets say your in 3th gear at 2500 rpm at 40 miles per hour and you down shift to second gear at that same speed you engine will be at 5000 rpm so if you don't match the RPM prior to let the clutch go the rear wheel has to force the engine to reach that RPM and in the process will cause a rapid deceleration (jerk motion) and can momentarily lock that wheel... so it all depends on the RPM differences between the gears at a set speed.
   / What is it with Harley riders? #236
Loud pipes are loud pipes on anything. One of my renters has a Dodge RAM pickup truck with a Cumapart turbo diesel and a straight exhaust that I get to listen to every morning at 6AM when he goes to work and little does he know that I based his last rent increase on his noisy 6AM exit. I find that exhaust noise irritating when it awakens me from sleep in the morning, so I compensated for it......lol
   / What is it with Harley riders? #237
I drove manual transmission cars for 30 years, until they simply became unavailable on the model types I was buying, and also usually downshifted to slow to a stop. I did it out of a combination of habit and fun, but one lingering thought always in the back of my mind was how much more work it is to replace a worm clutch versus worn brakes.
   / What is it with Harley riders? #238
Of you match the engine speed to the mainshaft speed on ANY transmission it will slip right into gear with no 'blipping' of the throttle needed whatsoever and no clutch wear at all because the dry clutch is never disengaged. Did that for over 40 years (and still do it today) with a big truck (diesel semi) as well as my tractors. Clutch's to me are optional and just for coming to a complete stop and starting out from a complete stop and I never replaced a clutch in a big truck either.
   / What is it with Harley riders? #239
Clutch only wore out in the friction zone while it's slipping (half engage) , rev match while down shifting might be harder on the motor (higher RPM while doing it then not and using the motor for breaking so bigger effort) if anything, but not the clutch if anything it is better on the clutch since you make the fly wheel spin at the same speed as the clutch during the point of contact.
edit: I must add that your method of breaking first and downshifting ''too slow'' at very low speed or RPM has the same effect as rev match for the clutch. I guess the advantage of rev match is you are always in the peak torque zone if acceleration is suddenly required, always in the proper gear and arguably a more control maybe also faster deceleration while preserving your breaks.
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
