What is holding this building up?
   / What is holding this building up? #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
What is holding this building up? I thought I would post this for a laugh. Could this be a helium filled building? Could it be attached with a sky hook? no wait I know its been photo shopped? You decide.
   / What is holding this building up? #2
I think the picture was taken with a fast shutter speed as the building was falling down the hill. :D
   / What is holding this building up? #3
Could it be attached with a shy hook?
It might be a shy hook :D but I would be more inclined to guess that it is large chunks of concrete embedded in the hillside holding the 6x4's in.
Aaron Z
Could of been, but not in this instance. :D
   / What is holding this building up? #5
I was going to build a dock something like that. I was going to use an old trailer house frame{metal I beams}. I would have had to bury and weigh one end{a lot} then have the other stick out over the pond.
   / What is holding this building up? #6
It looks improbable, like the weight of the building and the length and size of the beams would not support it.
I thought of building something your dock 20_20. I considered doing it by making an 'A' frame on each side that was well anchored on the shore end, then attach guy cables to the top points of the 'A' and run those back to more anchors farther up the shore. The steeper the shore, the stronger it would be. Never did it though.
Dave.
   / What is holding this building up? #7
I've heard of sky hooks, but not shy hooks....but I guess it might be shy a few hooks. :)
I fixed the spelling for you English ****'s out there.:D:D:D
I will put another pic up and I will say this it is not a doctored photo. I checked the spelling this time. Cut me some slack I am from WV, I have 5 brothers and sisters and it takes all 6 of us to make a 12th grade education.:D:D:D If we included some of our neighbors we could make a full set of teeth.:D:D:D OK I will quit.
   / What is holding this building up? #10
I can see now it's steel cables attached to the pipe and anchored back to the hill, you can see the posts that were removed.
Was this an experiment, doesn't look to safe.
Maybe it was done to replace sinking posts?
JB.
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
