What is best for killing all grass/weeds along fence line?
   / What is best for killing all grass/weeds along fence line? #12
   / What is best for killing all grass/weeds along fence line? #13
I have been using a non selective weed killer from Chemsearch at work for a couple yrs now. I am paying 22.50 per gallon, comes in a 2.5 gallon jug premixed, just pour in a sprayer and go. Has been very good, kills johnson grass and all the other weeds we have. I do have to respray every 2 months or so.I cant remember the name, but its something Maxx. I'll post the name tomorrow after i get to work.
   / What is best for killing all grass/weeds along fence line? #14
you mean ortho ground clear? i like the pricepoint on this one.
I just applied this a week ago on some of my driveway, so far I am unsure of the results
   / What is best for killing all grass/weeds along fence line? #15
I tried the ortho, but it did not kill the Johnson grass.It did kill the weeds growing up in the concrete seams around the buildings but not for a year, more like a couple months for me. I would love to find a weed killer I only need to apply once a yr.
   / What is best for killing all grass/weeds along fence line? #16
Vinegar is way more expensive than generic glyphosate.... which I can mix up for $.25/gallon and is probably a lot more effective. Vinegar is nice if you want to be organic though.
Be aware that once you spray your fence lines you will always have to spray them... weeds will be the first/only thing that comes back.
   / What is best for killing all grass/weeds along fence line? #17
Be aware that once you spray your fence lines you will always have to spray them... weeds will be the first/only thing that comes back.[/QUOTE
Where do you buy glysophate? How do you mix it?
   / What is best for killing all grass/weeds along fence line? #18
An over application of nitrogen fertilizer or lime should also work.:D
   / What is best for killing all grass/weeds along fence line? #19
I have tried Burnout II(citric acid, vinegar, clove oil mix) and worked well and shows instant results. Caveat is you need to reapply periodically, needs to be warm outside, and it is pricey if you have along fenceline to do. I used this for a hillside re-landscaping project at an organic community garden and it worked well. I went this way because it is organic certified and that I've seen environmental studies that are showing longer halflives for Round Up than was previously disclosed. Since I have several long rock walls I'm going to try something a bit different which is to take out invasive plants in and around walls and replace with fast growing, short wildflower mix. This Fall I will test a short wall section to make sure this works.
   / What is best for killing all grass/weeds along fence line? #20
Stringer - Forgot to mention that if the fenceline is off ground level, except for posts, you can also do a mechanical elimination of green material by using an attachment that uses a blade to undercut roots. These devices have simple sensory wands that pull back the blade when a post is reached. Vineyardists use this on tractors to keep vineyard rows clean of competing grasses/weeds. Pros - no chemicals, fast to complete task, and you're on the tractor. Cons - Pricey
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2018 FORD F150 XL SINGLE CAB TRUCK (A51406)
2018 FORD F150 XL...
2012 Ford F-550 4x4 Flatbed Truck (A55788)
2012 Ford F-550...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
Jumper Cables (A53316)
RIGID TOOLBOX (A52472)
