what is a swingshift transmission?
   / what is a swingshift transmission? #1
Legdoc
Can anyone explain what this design is compared to a regular gear drive?
Legdoc
   / what is a swingshift transmission? #2
The swing shift is just an electric over hydraulic shift on the fly range shift activated on the main shifter. You shift it by pulling back into neutral and bumping the left or right end of the neutral gate. There is still a non sync range change on a separate lever but it is a different set of gears.
The swing shift plus models also come with a 2 speed powershift using a thumb switch on the shifter that acts like a gear splitter in forward gears.
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A52377)
2017 Gravely...
19200 (A50324)
19200 (A50324)
