Mowing what is a good rough cut rear mower deck for a B7100 4X4?
   / what is a good rough cut rear mower deck for a B7100 4X4? #1
jpmurf
satoh
what is a good rough cut rear mower deck match for a B7100 4X4?
   / what is a good rough cut rear mower deck for a B7100 4X4? #2
My B2150 is not a lot different in capacity than yours. A 5ft bush hog for mowing weeds/grass works very well. I am sure a 5ft finish mower would work well for you.
I am concerned with correct drive shafts lengths, splines ,proper speeds, three point hitch compatible
   / what is a good rough cut rear mower deck for a B7100 4X4? #4
4' and not too heavy for rough cut mower. 42" if conditions are especially tough.
Regardless of brand, you will need to verify that PTO shaft is not too long so as to damage your tractor. Shortening PTO shaft is often necessary with small tractors.
anybody recognize this mower deck, would it go through heavier stuff?
   / what is a good rough cut rear mower deck for a B7100 4X4? #6
That's a finish mower. You don't want a FM for rough cutting. That's basically your lawn mower.
thanks
any model # / brand ideas? I need to find something decent , reasonable and in the Midwest
   / what is a good rough cut rear mower deck for a B7100 4X4? #9
   / what is a good rough cut rear mower deck for a B7100 4X4? #10
Most any common brand of cutter should suffice. Used 48" cutters are not common but do become available from time to time.
Be certain that the mower that you buy is not a heavy, HD model, which will likely be too heavy for your tractor.
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2017 Ford Expedition SUV (A50324)
2017 Ford...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
