What is a bog disc?
   / What is a bog disc? #1
BarryC
Davidson, NC
Yanmar 1610D
I am looking for a small set of discs and have found a set the guy calls a bog disc. What is the difference between a bog disc and a garden discs? I haven't yet went to the dudes house to look at them but the pics he sent look like there is only one row of discs instead of two. Confused...
   / What is a bog disc? #2
Bog discs are primary tillage implements used to cultivate land that hasn't been worked with a plow and has heavy sod and/or soft, wet areas. Offset discs (two axles in a V-configuration) are sometimes called bog discs since they are designed for primary tillage.
What you call garden discs generally have two rows of pans (the discs) in a symmetric X-configuration and are considered secondary tillage implements used on previously plowed ground to bust up the clods and fill in the furrows. They are commonly called tandem discs.
Thanks flusher! I'm new to owning a tractor and learning as much as I can everyday.
2012 John Deere 410K (A47384)
2012 John Deere...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Sudenga 10-72 Swing Away Auger (A50514)
Sudenga 10-72...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
