What implements would you suggest for my situation?
   / What implements would you suggest for my situation? #11
mowin said:
A grapple bucket would be at the top of my list...
X2.... You'll be amazed at how useful a grapple can be. If done properly it makes short work of small trees.
   / What implements would you suggest for my situation? #12
If your planning on continuing in farming for a long time look into investing in a skid steer style quick attach What is Universal Skid Steer Quick Attach . This will allow you to "swap" expensive attachments for relatively low cost. Moving items between platform is so much lighter on the wallet. I'm planning on moving my $7,000 backhoe from my B7610 to my M4700. For a $200 bracket.
Build up a spreadsheet of all the items you can think of and put in prices you find at B&M retailers, best online retailers, auctions, Craigs List for rapid reference.
I was searching Craigs List one night for pallet racking and up popped a Stihl 088 chainsaw for $450. Easily valued at over $1,000, the guy had to get rid of it, I got it the next day. You might find a boom pole for $10 because someone had to clear out the garage.
And for moving larger logs look for a log arch.
   / What implements would you suggest for my situation? #13
If you are mowing tall field grass you are probably producing "short" clippings, unless you are using a sickle bar or similar mower.
Picking up short grass clippings is tough. We do this and use the clippings for mulch. I had zero luck with various rakes.
The best way we have found is to suck them up with a Cyclone Rake.
I second newbury's idea of getting a log arch for log handling. I'll be making one in the next few months.
A set of pallet forks and some good, heavy pallets will prove surprisingly useful.
Commercial truck Frame with Axle (A59230)
Commercial truck...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
