What If I ran a 540 RMP pump @ 1100 RPM?
   / What If I ran a 540 RMP pump @ 1100 RPM? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
This is a hypothetical question...
I've got three speed settings on my PTO. What would happen if I ran a 540 RPM PTO pump at a higher speed...say 1100 RPM?
Would I get more flow less pressure?
More flow a the same pressure?
Just a big mess?
   / What If I ran a 540 RMP pump @ 1100 RPM? #2
More flow, more pressure - assuming you have the power to spin it faster. You will want to have a good relief valve in the pressure line. Check pump pressure spec and set it below that. If its a hydraulic pump you should do some homework to assure it can handle overspeed w/o cavitation.
larry
   / What If I ran a 540 RMP pump @ 1100 RPM? #3
Or shrapnel?
David from jax
   / What If I ran a 540 RMP pump @ 1100 RPM? #4
More flow, same pressure I believe.
You might be headed for disaster though.
   / What If I ran a 540 RMP pump @ 1100 RPM? #5
You should get more flow up to the fluid flow limiting sizing's of the pump. Maximum pressure should stay the same unless it is a PD type pump.:D
You may also want to consider a cage to catch all the pieces if it disintegrates!:D
   / What If I ran a 540 RMP pump @ 1100 RPM? #6
Egon said:
You should get more flow up to the fluid flow limiting sizing's of the pump. Maximum pressure should stay the same unless it is [[[not]?] a PD type pump.:D :D
think you left out a word?
larry
Next dumb question: What's a PD type pump?
How is it different from others? Why would it make a difference?
I love this forum! I always learn stuff here.
   / What If I ran a 540 RMP pump @ 1100 RPM? #8
PD = Positive displacement pump. If this type of pump is speed-ed up the increased volume flow resistance will increase the output pressure on an ongoing basis.
On a centrifugal pump this pressure will increase to a certain degree but stop increasing when the pressure limits of the vanes or stages are met.
   / What If I ran a 540 RMP pump @ 1100 RPM? #9
My understanding of a PD pump was one that displaced a set volume of fluid per revolution, like a gear pump.
If this is correct then would it produce full pressure at any volume, the max pressure being set by the tolerance of the gear lobes.
   / What If I ran a 540 RMP pump @ 1100 RPM? #10
Your pump would probably cavitate then grenade.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
197711 (A51244)
197711 (A51244)
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
1268 (A50490)
1268 (A50490)
