What I Learned by Renting a Tractor. . .
   / What I Learned by Renting a Tractor. . . #31
Very true K,
I was just answering Mred's question on what us foot pedal'ers (is that a thing now? :) ) do when we need a specific (say 2400 in his example) rpm.
   / What I Learned by Renting a Tractor. . . #32
I agree with slim. Foot pedal for most operations except high rpm pto work . not hard to understand.
   / What I Learned by Renting a Tractor. . . #33
That is funny Slim, I hate to think of what name will be used for those of us that like to run things by hand! :laughing:
   / What I Learned by Renting a Tractor. . . #34
I think renting was a good idea but for the type of things you plan on doing a 30hp tractor is too small. One thing you will need to remember is if you have a cab you will want AC. Just having it alone would mean adding an extra 5hp IMO. A 7' brush hog is going to need at least 35hp at the PTO, that's at last a 45hp tractor. Once you get in that range the HST wine is nothing like what a smaller tractor will make. HST will require at least 5hp to 10hp over a geared tractor. I personally wouldn't go with a geared tractor unless most (75%) of what I plan on doing was going to be shift into a specific gear and leave it there. Stuff like loader work would drive me crazy trying to do it with a stick.
My backhoe is 'shuttle shift' or sometimes called 'power reverser', very similar to GST. You pick the gear and then a level shifts between forward, neutral, and reverse. Once you get over 60hp it's pretty much your only option vs gear. It's like an automatic car. You have to rev the motor up to move. This means that if you are doing PTO work (like a brush hog) when you slow down to take a corner or turn around the attachment also slows down. It's also why others are talking about the hand vs foot throttle. With HST you set the RPMs you want and then control the speed the tractor moves forward with the foot pedal or cruise control lever.
Yep, I would say 65% of my use will be mowing. The rest of the work will be varied, and a gear drive wouldn't be an issue. And YES, that tractor I rented was too small. When I was window shopping for NEW, I was looking at the Kubota L4701, but now that I am looking at USED, I am looking at the 55-70hp range. There are a decent amount of low hour machines out there in that HP range for under $29K. I would like to try one of the "Glide Shift Transmissions" or "Shuttle Shift Transmissions" to see what that is all about.
I will probably have to rent a tractor at least once, maybe two times, before I buy. I just wish I could find a place that rented something other than the JD 3038e. But that seems to be the go-to rental around here. The weeds in my pastures will be ready to mow in another month.
Thanks so much for all the input! ! !
   / What I Learned by Renting a Tractor. . . #36
K, how many people on here use their brakes to steer?
   / What I Learned by Renting a Tractor. . . #37
Kinda rare but every once in a while I do use the brakes to steer. But with 47º turning angle, it's not needed that often. I can squeeze on the orchards just fine.
   / What I Learned by Renting a Tractor. . . #38
I do but not near as much as when we were row cropping. If I use all 47 degrees of steering on the Branson I will to relieve pressure on the front end.
   / What I Learned by Renting a Tractor. . . #39
I do for sharp turns. Like mowing around trees or cactus. You better have your seat belt on! :p
   / What I Learned by Renting a Tractor. . . #40
I use my split brakes all winter long while pushing snow.
Other than that, I don't think I use them any other time.
Like others have said, the turning radius is so tight on mine as well, you can turn a 180 and the inside rear wheel barely moves.
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2014 BMW 5 SERIES SEDAN (A59575)
2014 BMW 5 SERIES...
