What have you hit with your mower lately?
   / What have you hit with your mower lately? #51
Whoever is building always throws their scrap, trash, excess fill and concrete truck cleanout on the adjacent vacant building lot.
Mine field is a more suitable term.
   / What have you hit with your mower lately? #52
Yesterday after a day of mowing some pretty gnarly trails with the brush hog, I noticed a spot on the way home that I had missed. No problem, popped the PTO on and backed into it. I immediately caught something so big it stopped the tractor dead. Thankfully I had just slipped my clutch the day before, or I can't imagine...
The culprit was a big fat wad of old rusty logging winch cable hiding so well I couldn't see it when walking around. New set of blades are pretty wrecked from it, I'm still cursing today!
   / What have you hit with your mower lately? #53
I actually hit my chain guard when it fell off. I have an 8' dual spindle brush cutter. Hitting the chain guard broke a blade and bent the others. The spindles and stump jumpers were OK.
   / What have you hit with your mower lately? #54
Piece of firewood- hit it with the belly mower on my Kubota BX. Sheared the bolt holding blade to the spindle- deep inside the spindle. New spindle needed but easy fix and only cost 30 bucks.
   / What have you hit with your mower lately? #55
Have hit small rocks, big rocks, huge rocks, old house ruins, stumps, big logs, old steel bed frames, thick rebar, concrete blocks, random pieces of steel, stoves, fencing net. The list goes on and on beyond what I can remember.
Popped a couple shear pins with some of the hardest hits, but I typically just wear them out with all the beating it takes.
Still rocking the original "blades" that came with the mower and didn't even got bent once. :)
That is unique. I have never seen a "chain mower" before. I'd think it would beat up the grass and weeds rather than cut it. Sometimes that would be OK, sometimes not so good. Still very interesting. Thanks for posting.
   / What have you hit with your mower lately? #56
Ran over a roll of chain link fencing that was covered by some brush. Took me a while to cut it out from the blades. Had to disconnect the mower and use my FEL to raise the mower on its side (with a chain) so I could get in there with bolt cutters. Chain link is tough stuff.
   / What have you hit with your mower lately? #57
Issue with ditch mowing is people discard all kinds of stuff in ditches, called littering, I call it dumping junk. I do a couple fields with drainage ditches (deep) on their borders. The roadside ones are particularly suspect. Everything from old tires to bed springs to garbage bags full of garbage tossed in the ditch. People are lazy pigs.
Amen brother... my 7ft Bush Hug usually stands most anything you throw at it. Cleaning up an old farm takes forever and the debris you hit is just not predictable. My BH seems to pulverize unseen head-sized rocks with only a lot of noise and no damage.
I did hit a hidden boulder last year that was around 2 feet in diameter and stood 10 inches or more high. Left over from strip mining decades ago and the grass completely obscured it. Tractor straddled it so my first clue was when all hell broke loose at the hog. Severely bent heavy blades but surprisingly did no other damage. Gearbox is fine. Of course this was while mowing free for a neighbor who owns no equipment... New blades from the dealer are $105 and getting the old blade bolts out of the blade carrier was impossible at home. Shop had to heat it, suddenly cool it, and even then had trouble driving out the blade bolts. Even if that were not an issue the torque on the bolts is in the 500 or 600 ft-lb area. I got the nuts off OK but that was the least of the problems.
My typical bush hog stoppage and unravel issues over the years have been barbed wire, polystyrene twine, surprise stumps, old posts not quite rotten enough, iron fence posts some nut left in the field, and worst cases are pretty much always in places I had not mowed before -- those are ALWAYS scary. Very rarely had to do anything other than to unwind the trash. The steel fence posts and rocks have always lost to the hog. I am amazed how hard that blade steel is.
   / What have you hit with your mower lately? #58
i use my mower to find sprinkler heads and hose bibs...
   / What have you hit with your mower lately? #59
Bought an old home place that was never fenced, so folks being lazy, just pulled in and dumped stuff on the place behind the trees. That was after the house was burglarized and then burned to cover the burglary.The prior owhers just had the junk pushed up with a dozer. I found junk scattered for 1/4 mile, through volunteer trash trees.
I have hit just about everything, plumbing, kids toys, pieces of appliances, bed springs, etc.
My favorite item was a 2” galvanized well pipe with a 1” pipe insert, in tall grass, went right between the root rake forks into the bush hog, cut almost half way through both pipes before it shut down the tractor. That Squeeler is one more tough bush hog as is the Kubota 45 hp standard trans 4x4.
Oh, I finally got a D-8 with a blade and root rake to push the mess up into a big pile, dug a pond, then buried the pile in the bottom 10’ below the pond bottom.
   / What have you hit with your mower lately? #60
I ran over a womans bra in a field with a 7' BushHog Squealer , just temporarily slowed my blade speed down . Later later I discovered a piece of it with the wire caught up under my bushHog blades /stumpjumper . I could barely read the tag on it however it said "48D " . :cool:
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
2017 PJ TRAILER 20' T/A TRAILER (A58216)
2017 PJ TRAILER...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
