What happens when you "power reverse" at speed?
   / What happens when you "power reverse" at speed? #1
Ken_S
Nebraska
JD 4710
What happens when you \"power reverse\" at speed?
I took an informative test drive, on a 4610 with "Power Reverse" manual transmission. I was very impressed with the ability to power reverse with just a flip of a lever.
Question for anyone: what would happen if you hit the lever while rolling at a very good speed? Wouldn't something break?
I should have asked the dealer this one; please forgive the dumb question.
   / What happens when you "power reverse" at speed? #2
Re: What happens when you \"power reverse\" at speed?
Ken, that's a great question and I would expand it to "how does a power-reverser work?" I ran a friends dozer with a similar transmission feature and it really got me wondering how it could do what it did. Only thing I could figure is it must have two clutches, a forward and a reverse. One disengages while the other engages. If that were the case, reversing at speed would just mean more clutch slippage and shorter clutch life. Anyone out there really know what makes these things tick?
/forums/images/graemlins/smile.gif
   / What happens when you "power reverse" at speed? #3
I am pretty sure that the little "e" in ePowreverser comes to play here. It is electronically controlled to keep all the monkeys working the right way.
   / What happens when you "power reverse" at speed? #4
</font><font color="blue" class="small">( I am pretty sure that the little "e" in ePowreverser comes to play here. It is electronically controlled to keep all the monkeys working the right way. )</font>
OOps I guess the 4610 doesn't have that little "e" does it?
   / What happens when you "power reverse" at speed? #5
Whiplash!!!!!!
Black eyes !!!
Brocken Wrists !!!!
Chipped TEETH!!!!!!!!!
I have a 4310 with the E-PowerReverser, the faster you go foward, the faster you go backwards. Same gear each way, I still use the clutch unless I'm on flat ground and have lots of room to brake.
Can't seem to get used to not having to push in the clutch before I change direction.
Dt
   / What happens when you "power reverse" at speed? #6
Nothing happens. You can be going forward at a good clip and go into reverse. It will slow down and then go into reverse. I wouldn't do it all the time but I've done it a few times and no metal clanking or whiplash effects.
   / What happens when you "power reverse" at speed? #7
My Massey works like the way cowboydoc says.
   / What happens when you "power reverse" at speed? #8
say what you will, JD made a good choice on the pwrrevsr, it is slick and sliky smooth to operate,no jerky moves at all,just fwd and back. /forums/images/graemlins/grin.gif
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
10" Backhoe Bucket (A56469)
10" Backhoe Bucket...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
6 Cubic Yard Dumpster (A55851)
6 Cubic Yard...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2015 Deere 524K (A53317)
2015 Deere 524K...
