What Happens When a Hydraulic Pump Can't Get Oil
   / What Happens When a Hydraulic Pump Can't Get Oil #11
It's unlikely a frozen sump would cause this but if the oil in the pump was frozen, it's possible.
   / What Happens When a Hydraulic Pump Can't Get Oil #12
Some Grand L series Kubota tractors had a problem when using tractor for extended periods of time with a front down attitude down a hill or such the pump drive gear and shaft were starved of oil and the pump drive shaft would shear off The Kubota fix was to put on a new pump holder with a port drilled between the gear and bearings with a supply line with restrictor coming off a new oil filter holder. So do check the pump drive shaft and bearings also there could be a problem there.
David Kb7uns
It seems that the damage was limited to a sheared off key. No bigggie, but I am stilll curious why. The tractor worked fine, was parked overnight in very cold conditions and then failed on start up.
   / What Happens When a Hydraulic Pump Can't Get Oil #14
Well now, can a frozen pump even turn?
Perhaps the pump froze because of some water in the fluid. The engine would turn over, but the shaft might shear off or strip the gears.
He did report that his hyd fluid was very milky and he intends to change it.
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2025 Swict 72in Bucket Skid Steer Attachment (A55787)
2025 Swict 72in...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2018 Ford F-150 Crew Cab Pickup Truck (A55788)
2018 Ford F-150...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
