What Happens When a Hydraulic Pump Can't Get Oil
   / What Happens When a Hydraulic Pump Can't Get Oil #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
A friend was having trouble with his White 1265. I thought it was a frozen sump. Anyway, in the end it truns out the drive on the pump sheared off, and it was a year old pump.
I know with a positive displacement pump, you can blow the pump apart if the relief isn't working. It happened to the same guy with a Bolens/Iseki tractor.
But what happens when a positive displacement (Gear) pump can't get oil on account of a blockage?
Could this have caused the mechanical drive failure?
   / What Happens When a Hydraulic Pump Can't Get Oil #2
It could get hot enough internally (no lubrication) to seize and break the shaft, not necessarily what happened but possible.
Apparently, the pump is OK, just the mechanical drive connection broke.
   / What Happens When a Hydraulic Pump Can't Get Oil #4
It must be a hi pressure fault then. Loss of feed oil will not break a shaft w/o some other damage occurring 1st.
   / What Happens When a Hydraulic Pump Can't Get Oil #5
Sounds to me like he is running the wrong fluid. If to thick of fluid is run in very cold weather it can and does cause pump problems.
   / What Happens When a Hydraulic Pump Can't Get Oil #6
Which pump failed ? Steering / hitch or loader?
That tractor has a fiat engine, pumps have always been problematic.
NOT the steering pump. Apparently a year ago someone put in a larger pump saying he needed that as he as a FEL.
He was using the loader a lot one day, put it away, and the next day said he lifted the 3ph and then it was all she wrote. Reading other posts, and with the extreme cold at the time, I was certain that it was an ice issue in the sump.
   / What Happens When a Hydraulic Pump Can't Get Oil #8
Any chance we could see photos of the broken shaft, often the failure can be determined by the grain pattern of the break.
It has been repaired. I can ask more questions. The guy wil be here tomorrow. I ust kind of was wondering if a frozen sump could cause such failure.
   / What Happens When a Hydraulic Pump Can't Get Oil #10
If a chunk of ice could get sucked into the pump it could stop it.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2020 Terex RL4 Towable Light Tower (A55787)
2020 Terex RL4...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
