What Happened to my Picture?
   / What Happened to my Picture? #1
RobS
Super Member
Goshen, IN
None!
So last night I take a fresh photo of the house. The sun is in the back so I do what I can with the digital to compensate. I locked the exposure on a darker spot to trick it. Sorta, kinda worked. Got home and the picture looked OK, but not great. I posted it and looked again and it was the same. Got to work this morning, looked at the picture and it's much darker than what I saw last night. Here's the picture <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/33-167878-Porch.JPG>House</A>.
What happened and how can I improve?
Thanks all /w3tcompact/icons/smile.gif
OK, I tweaked it with MS-Photo Editor but still don't understand why it got darker over the 'net?
   / What Happened to my Picture? #3
I'm sure when you get back home tonight, the picture will look fine to you again. The settings on your two monitors are different.
   / What Happened to my Picture? #4
Morning, Rob. I've had similar problems which is why I've changed the metering setting on my camera to spot metering. For some reason, many of my pictures have subjects that are back lit. I don't know if the attached is an improvement on the second picture you posted or not.
<font color=blue>I've changed the metering setting on my camera to spot metering</font color=blue>
Thanks for the help Mike but unfortunately my digital camera has no such frills. Kind of frustrating since my 35mm has plenty of features to help with backlight and such. I guess I'll have to master one of the photo touch up software packages /w3tcompact/icons/smile.gif
   / What Happened to my Picture? #6
Love the turret and the wrap around porch! What do you call that style of house? It seems to be quite popular with the folks here on TBN. Is it supposed to be victorian? Our houses here in the south look similar but with a much wider footprint./w3tcompact/icons/smile.gif
Jeff
Thanks Jeff. Our house style is called Queen Anne which is a subset of Victorian. The real ones were built between around 1880 and 1910 /w3tcompact/icons/smile.gif
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
