What guage wire to use
   / What guage wire to use
Yes, there are 4 wires in total, red black white and ground. I'd rather be a bit over than a bit under too.
   / What guage wire to use #12
8-3 UF wire si good for 40A.
Wondering why your electrician is suggesting 6-3? (which is good for 55A). Maybe because he already has some on had?
Also, not sure what type of breakers you have, but it may be a bit difficult putting 6ga on a 40A breaker.
As far as length, you can go to 125' pulling 40A on 8ga before you exceed 3% voltage drop. So I dont see that being a reason to upsize wire either.
Now you may want to see if there is anything you can do to get the circuit length to 50'. Wire comes standard in 25', 50', 125', 250, etc rolls. See if you can make 50' work and not have to buy 125' of wire, and not use 70' of it.
BTW, 50' 8-3UF is ~$90
.......125' 8-3UF is ~$190
I bought the 6 3 yesterday. Actually needed 18 meters and it cost 244.00. Everyone I talk to says use #6, I assume it's a local standard.
   / What guage wire to use #14
Wow, thats pricey. Can get 50' here for ~$110 and 125' for about $300
   / What guage wire to use #15
Usually a good idea to run a 12/3 out there at the same time to power a pair of 20amp T-slot GFI plugs in the yard.
Either net for wifi too.
Welcome to Canada, the land of the overcharged.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
Electric tri scooter irgc40 (A56859)
Electric tri...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
