What gives?
   / What gives? #1
yoyo
Bronze Member
NC
Kioti CK25HST
My HST speed control is not holding. When I set it, it starts slipping and the tractor slows down. Does anyone know how to adjust it?
David
   / What gives? #2
The cruise lever on my Cub is like a brake. I needed to adjust it to hold the pedal tight for cruise. Check your cruise lever for an adjustment.
   / What gives? #3
I imagine that your cruise control is much like my CK20HST.
There is a rod coming down from the control in back and you will see some adjusting nuts on it near the bottom. Loosen those jam nuts, moving one up on the rod so that it causes the control to be tighter. Then retighten the jam nut onto the one you moved up. So that you get an idea of which way to do it, look behind the instrument panel, move the control lever and watch the action of the rod. You will see how it pulls and then can adjust it for a tighter cruise. John
   / What gives?
Thats's just what I did John , but after just 2 -3 turns of the nut, it stoped working altogether. So, I went the other way with the nut, and it got loose and didn't even pull the rod any.
David /forums/images/graemlins/confused.gif
   / What gives? #5
</font><font color="blue" class="small">( Thats's just what I did John , but after just 2 -3 turns of the nut, it stoped working altogether. So, I went the other way with the nut, and it got loose and didn't even pull the rod any. )</font>Call the dealer and let him deal with it as it is a warranty issue. I had the same problem in the beginning, but I was able to adjust it out. After you turned it two or three turns and it stopped, did you try the control again to see what difference, if any, it made? John
Edit: one more thing, look to see if it looks as though you could turn the rod itself to change it's position. Don't do too much and be careful about scarring anything as you don't want to void the warranty. J
   / What gives? #6
let me guess...this only happens in hi range, correct?
   / What gives?
No, mid range is what I was in. I'm not sure about other ranges though.
David
   / What gives? #8
On my CK20H, the cruise only works correctly in low range, and it does exactly as you described in hi range...i've not had the time to investigate adjusting it as John described...sounds like a weekend project!
   / What gives? #9
</font><font color="blue" class="small">( On my CK20H, the cruise only works correctly in low range, and it does exactly as you described in hi range...i've not had the time to investigate adjusting it as John described...sounds like a weekend project! )</font>
I think it took me all of 10 minutes. John
   / What gives? #10
My new CK30's cruise is doing the samething. Works OK in low range but when it's set in mid or hi range the tractor slows to a stop. Did you manage to get it adjusted so it works right?
I just read KiotiJohn's post and will try to adust it tomorrow to get it to hold.
AL
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
27 Challenger Boat (A50324)
27 Challenger Boat...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
