What Ford Backhoe model is this?
   / What Ford Backhoe model is this? #1
777funk
Yanmar/336D
My son just picked uo this backhoe and we're trying to find the model. Looks to have been painted Ford Blue long ago over top of the industrial yellow.
It's 23' long and 80" wide. It has a 3 cylinder diesel.
   / What Ford Backhoe model is this? #2
Hard to tell without more pics. Looks like maybe a 4500, 1960's vintage.
Thanks, was sold as a 550 (he was going by an old manual he had), but I am sure it's not now.
It's all clutch and mechanical trans. No hydrostatic.
I will get a few more pics loaded.
   / What Ford Backhoe model is this? #5
I think it is older than a 550, I had a 4500 and yours looks like it. I can tell you if your boom swing is leaf chain driven, that is the weak link
in the otherwise good machine. And there are (2) grease fittings on the center of the front axel, one greases the pivot, the other that is often missed greases the steering bushing. I had a thread on it back in 2011. If I wasnt computer illiterate I would post a link.
I will follow along in this thread and hope I can help from time to time.
   / What Ford Backhoe model is this? #6
   / What Ford Backhoe model is this? #7
I forgot to mention and you may already know, your loader frame is the hyd. reservoir so dont drill or weld on it.
Good to know and thanks! I guess it wont rust from the inside then!
   / What Ford Backhoe model is this? #9
I believe you'll find the numbers you need on the upper right front corner of the transmission. There's a horizontal flat surface with all the ID numbers stenciled into it. If you find those numbers post them all here and someone will tell you exactly what the tractor is right down to the day/shift that it was built on.
Alright I took a look at the right front corner of the transmission and here is the number: CSNN7006CD
Thanks a lot for all the help.
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
Genie GTH-644 (A50490)
