What Fasteners to Use With Aluminum Tubing
   / What Fasteners to Use With Aluminum Tubing
Thanks, I'll bookmark that site.
   / What Fasteners to Use With Aluminum Tubing #12
You should also look into sacrificial zinc, especially if you plan to leave the boat in the water. Zinc is less noble than aluminum or stainless and will absorb the worst of the galvanic reaction. In time the zinc will deteriorate and can be replaced. There are usually parts on the lower unit of outboards that are made of zinc and are easliy replaced. You can also buy a block of zinc and wire it to the boat to toss overboard when at dock (an example here). Always keep your motor out of the water when docked which will also reduce or eliminate the problem.
2014 International Bucket (A55973)
2014 International...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
golf cart (A55758)
golf cart (A55758)
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
