What factors make loader specs so close - yet so different?
   / What factors make loader specs so close - yet so different? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I've been comparing a Kubota B3300 and L3800 on their specs (trying to make a purchase decision) - and their is something that is bugging me - because it sort of doesn't make any sense.
When I look at the loader specs for the two tractors I see:
Lift capacity (pivot pin) :
B3300SU (LA504) = 1065
L3800 (LA524) = 1131 (max ht.)
Lift Capacity: (forward) :
B3300SU (LA504) = (19.7in) 730
L3800 (LA524) = (500mm) 855 (max ht.)
Breakout Force (pivot pin):
B3300SU (LA504) = 2474
L3800 (LA524) = 2462
Breakout Force (forward):
B3300SU (LA504) = (19.7 in) 1737
L3800 (LA524) = 1874
The breakout force at the pivot pin on the two loaders is very close. Yet - the forward numbers on breakout force are a lot different. The lift capacity at the pivot pin on both are close - but they are farther apart on the forward number.
Is this a leverage thing? Or is the cylinder diameter affecting some numbers more drastically than others?
   / What factors make loader specs so close - yet so different? #2
My guess would be leverage or mounting location of the curl cylinders in relation to the bucket pivot point.
Hydraulic cylinders provide a constant force at a constant pressure.
   / What factors make loader specs so close - yet so different? #3
I am think it all relates to the geometry of the boom cylinders. The relation ship to their mount position on the mast and boom and the distance from the boom pivot pin to the bucket pivot pin.
My definition of breakout force is the bucket lift force at the ground level using the boom lift cylinders.
Bucket rollback force would be using the curl cylinders.
   / What factors make loader specs so close - yet so different? #4
Excerpt:
Here's what Cat says the SAE (Society of Automotive Engineers) definition is for wheel loaders:
Breakout force is the maximum sustained vertical upward force exterted 100mm (4" behind the tip of the bucket cutting edge and achieved through the ability to lift and/or rollback about the specified pivot point under the following conditions:
Here is what Case says about the 1845C
The maximum rated operating load of the Case 1845C is 1,750 lbs., and the tipping load is 3,545 lbs. The breakout force of the bucket and lift arm is the maximum force that the machine is able to exert. The breakout force of the lift cylinder is 3,450 lbs., and the breakout force of the bucket cylinder is 4,690 lbs. With the bucket loaded it takes 4.3 seconds to raise the lift, 2.9 seconds to lower it, 2 seconds to dump the bucket and 1.4 seconds to roll back the bucket.
More breakway/breakout force is achieved with the combined power of the loader lift and bucket (crowd-dump-fill) cylinders. The combination of a tractor/loader's weight, hydraulic lift capacity, loader design, traction all are important ingredients to determine how much "breakout" force the equipment may develop.
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
